Ciao,
is there any way to extract the string vector of the elements ID when quering a *.h3d file?
Thanks
Liv
Liv,
If you want to extract the element ID's, you can use 'getreqlist' command.
syntax:
request_list = getreqlist(filename, datatype)
request_list = getreqlist(filename, subcase, datatype)
--> you will get a cell variable 'request_list' with element ID's with a prefix letter 'E' like ( E1234, ....)
and if you want to get the element id's in a matrix, you can do something like below :
elementid = regexp(request_list,'E','split');
for i = 1:length(request_list) elem(i,:) = str2num(elementid{i}{1,2}); end
Thanks,
Manoj
