I am practicing RCS calculation and took the FEKO webinar recording presented by Martin Vogel. (Link : http://web2.altairhyperworks.com/feko-webinar-rcs)
In the webinar, 3 step process was introduced to reduce computational cost, and inlet interior was set 'absorbing' (Time 24:45)
However, I could not find the detailed way to set absorbing surface when I tried to repeat the process with simple rectangular closed cavity.
I had internal surfaces set as waveguide port without source to make termination and it worked with MoM solution when just single internal surface was set to waveguide port. But it didn't work when multiple surfaces was set to waveguide port (Error occured and the program could not proceed the calculation)
So, how can I find absorbing setting at surface?
I would really appreciate if someone can solve this problem.
