I have a stamp forming model output from LsDyna.
I would like to get a surface strain ratio contor for the model.
Is it possible?
Thank you
Yes, it is possible to get strain ratio contour plot. But for that you need to write macro in HyperView. In this macro nodal contour values can be obtained and then applying ratio formula on those values, then interpolating new values on node\elem, contour can be generated.
Please fill free to ask more...
