I would like to know how to find elements that fail the validity check and then delete them. Is there a method to do so in tcl?
Thank you
Hi @etrud011,
you can record the command using F10 panel and use it accordingly, for example
*createmark elements 1 'displayed' *createmark elements 2 *elementtestjacobian elements 1 0.7 2 2 0 ' 2D Jacobian ' *deletemark elems 2
*createmark elems 1 displayed
hm_getelementsqualityinfo 1 0 2;
*deletemark elems 2
Thank you Pandurang and Vipin!
I am trying to delete tetra4 elements with aspect ratio above 10^5. But hypermesh is telling me that the aspect ratio some of those elements is 4.12 and will not create a mark on them for deletion. Optistruct will not start because there is a validity check fail due to aspect ratios above 10^5. How is that possible?
The code I am using is below;
*createmark elems 1 'all'
#does not find problems elements set elems_ids2 [hm_getelemcheckelems 1 3 aspect above 100000]
It does not find the problem elements. Also I do not understand how to use 'hm_getelementsqualityinfo 1 0 2;', it returns zeros each time.
Edit2: The problem was that I was looking at the wrong aspect ratio type.
