How to create any contact surface from the given menu (image) attached below
https://drive.google.com/file/d/0B2rIYPnVjYNESUFvQXVGaVZsX0U/view?usp=sharing
Here is the problem i want to get resolved
https://drive.google.com/file/d/0B2rIYPnVjYNEdkVKNmxyWHN1WWc/view?usp=sharing
Note: I use abaqus for solving
Please refer to the tutorial HM-4320: Defining Abaqus Contacts for 3-D Models in HyperMesh
Thanks. It was helpful.
Hi Ahilan,
When you define faces of the solid elements (which are used to define the sruface nodes), be sure to use a temporary collector for the elements. If you use face elements provided by hypermesh, at the time you create the surface the face elements will be deleted by hypermesh.
I usually create the face elements, then move the elements to a temporary collector so hypermesh cant delete them. Then you can select the nodes using the new face elements in the temporary collector.
