I want to select elements which are covered within a large circle. What is the best way to select such elements ?
Mask those elements which are hindrance to select desired elements
To select elements within a circle,
Shift + Single click and release of the mouse displays the entity selection pop-up menu:
From the entity selectionpop-up menu, choose one of the first six quick window selection modes:
•Inside of circle selects the entities that are inside of a circle window.
You can use circular clipping pattern to pick elements of circle.You can activate same using shift+mouse button left hold for 2 second.
See attached thumbnail.
Regards
Rahul R
how do i get these options in Hyperworks 2019.1X ?
Narasimhamurthy
Right Click anywhere in the window:
