I am new in using HM. In my research I use hm to mesh the object into finer triangular grids, even seveal millions of grids! But when I set the element size in the 2d auto mesh, the information was that the element size must be greater than ... for example 0.0023333. Note that not 'must be greater than the node tolerance'. I have already set the node tolerance smaller than the element size.
what should I do next? Thank you!
