I have to delete temp nodes created on particular line/face or group of lines.
Is it possible to select tempnodes on a particular line/face or group of lines.
Any Ideas??
Thanks in Advance
Sateesh
Sateesh,
Yes, it is possible. Use the node selection option based on GEOMETRY, it will list option as solids, surfaces, lines and points
Thanks & Regards,
Nithyanandham
Goto temp node menu, select node based on goem, it lists option as lines, surfs, solids, points.
Command line
*createmark nodes 1 'by lines' 537(line no.)
*nodemarkclear 1
