Hello all,
I would like to build a model with several components, but with continuous mesh between them. As an example, I attached a screenshot of the demo file of the truck. I circled 2 locations where this happens : different components but a continuous mesh. How is this done ?
- Should I import my components as one and split them later by selecting each component's elements ?
- Should I import them seperately and mesh them in a way I don't know ? I already tried to mesh to seperate elements at once. They are imported from solidworks software, where I impose a face coincidence. So the surfaces should match but the mesh doesn't.
How to work this out ?
Thank you in advance,
Alice
