Support,
How is gravity applied to the mesh in HM? Are all nodes selected and then a magnitude specified?
Regards
B
what problem you are facing while applying gravity load?Is it the direction of load?
Use Load Step browser>> DLOAD>> Gravity>> and select element set to chose a particular rregion or select all elements.,
Thanks Prakash,
I will try this. How do I know which direction it is acting? Ie, does it give a choice of coordinates?
Use components to specify the direction.
I am having he same problem. I wan to apply graviy in a problem of forming. I cannot find where is the Load Step browser in Hypermesh, can you help me?
Thanks
Thanks.
I know why I didn't find it. Because I am using the RadiossBlock (Block140) and your screenshoot is fom the Abaqus (Standard3D) isn't it?
