Hi Friends,
Define aspect ratio in HM.
Plz see Hypermesh help
This is the ratio of the longest edge of an element to either its shortest edge or
the shortest distance from a corner node to the opposing edge ('minimal
normalized height'). HyperMesh uses the same method used for length (min)
described below.
For 3-D elements, each face of the element is treated as a 2-D element and its
aspect ratio determined. The largest aspect ratio among these faces is returned
as the 3-D element’s aspect ratio.
Aspect ratios should rarely exceed 5:1
Thank u very much analysis....
