hey anybody knows how to open hypermesh v11(.hm) file in v10?
Thank you.
You can export the hypermesh (V11) model in any solver format and then can import the same in hypermesh V10.
For Export
File-Export- Solver deck model
For import
File-import-solver deck model
You can export the hypermesh (V11) model in any solver format and then can import the same in hypermesh V10.For ExportFile-Export- Solver deck modelFor import File-import-solver deck model
great
You can export out the .fem, then open it and edit the lines where it defines the solver/version and replace them with the lines from a 'good' v10 .fem file. It should then be import-able back into v10. This works for v12 .fem to solve in v11 solvers so I 'm assuming you can do the same for your issue.
You can export out
