Hi there,
what would be the difference between tet and hex if both has been used for the same component . will the output makes any difference.
if it makes difference , will it depends on the component size.
regards,
chandru
Linear tetra elements are not recommended for structural analysis. They are very stiff and inaccurate, so use parabolic tetra (the second order tetra)
