*** ERROR 14: Missing property
Hello all,
I have the following error message : *** ERROR 14: Missing property #386728 referenced by CQUAD4 # 386728.
*** ERROR 14: Missing TABLES1/TABLEST #1000100 referenced by MATS1 # 1000100.
But I dont know why. I searched the Element 386728 and checked if there is a missing property. But everthing is fine. Furthermore I dont know what to do with the missing TABLES1? I did not put any MATS1 in the material card.
I would appreciate any help
Hi Novus24,
Check if you have applied a PSHELL property to the CQUAD element 386728. If the element is not compatible with the property it throws this error.
if you are using non-linear material using MATS1, you need to input the stress strain curve using TABLES1 card and the same should be referenced in MATs1
0 -
Hi Prakash,
you are really fast /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'> I checked evething but it was the PSHELL prop.. I just did not see it
Thanks a lot
0 -
But I found something different. I am considering a cut part of a bigger assembly with a lot of joinings. Due to the cut of the whole structure, there a many rbe2´s which are not connected anymore to its partner element. When I am starten the simulation, the solver error give me the id of the false defined rbe2. But it only gives me 1 error and not all of them.
Is there any possibility to check the rbe2 before starting a simulation run?
0 -
You can use model checker before running any model.(Tools: model checker)
Regards
Rahul R
