I want to take a snap of output without the file path.
what do you mean exactly?
If you wish to remove the path name at the model info notes, then replace the following lines:
Model info: {window.modelfilename}
with
Model info: {window.shortmodelfilename}
Result: {window.resultfilename}
Result: {window.shortresultfilename}
Best regards,
Mario
Hi
this is my doubt
https://drive.google.com/file/d/0B2rIYPnVjYNELWJJT0FVZDhKRnM/edit?usp=sharing
Hi this is my doubt https://drive.google.com/file/d/0B2rIYPnVjYNELWJJT0FVZDhKRnM/edit?usp=sharing
See this screenshot: http://s15.postimg.org/gztgoyiej/hv_model_info.png
Thanks Q.Nguyen Dai
Also how to remove the 'Model info :File path ' from Hypermesh window ? ( i don't find any similiar options in preferences / settings )
In the Results browser (left side of your HyperView screen)>> expand notes>> you will see Model Info with a text bubble icon. Click on the text bubble icon to turn off model info.
Sir i got it. Also I want to remove ' Model info :File path ' from Hypermesh window.
Sorry for my confusion. I thought it was for HyperView. I apologies.
You can hide Model Info in HyperMesh as in HyperView.
in Model browser>> expand Title>> and click on the text bubble next to Model Info.
