How to Get the Maximum principal stress plot in Hyper view?
Regards
Arun
If you have in your results file the stress as a tensor quantity (the Result type has a (t) in the name), you can directly select in the contour panel the major principal stress.
dear Hettel,
Thanks for your suggestion
Above query i got the solution from Altair support.
In HV
Load Model : *.fem file
Load result : *.res file
This way i tried i got Maximum principal stress plot in HV.
