Failed to read hstp file
In the testing part of hyper study model, after run, the flux software is executed, when the desired file is selected and batch solve is selected, the flux software does not close after finishing the solution, I have to close it myself, but when I close it, hyper study gives an extract error.
Thank you for your advice
task__exe_stderr:
[16|1702109618102|1|WARNING ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Unable to get folder, key: dll.win32.dir
[18|1702109618102|1|WARNING ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Unable to get folder, key: dll.lin32.dir
[19|1702109618103|1|WARNING ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Unable to get folder, key: dll.lin64.dir
[21|1702109618103|1|WARNING ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Unable to get folder, key: prog.win32.dir
[23|1702109618104|1|WARNING ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Unable to get folder, key: prog.lin32.dir
[24|1702109618106|1|WARNING ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Unable to get folder, key: prog.lin64.dir
[28|1702109618106|1|WARNING ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Unable to get folder, key: bestpractices.dir
[31|1702109618106|1|WARNING ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Unable to get folder, key: user.dir
[75|1702109621905|1|WARNING ][class org.icepdf.core.pobjects.Document|Document.<clinit>] : PDF write support was not found on the class path
[82|1702109622074|1|WARNING ][View|View$Listener.updateNewProjectBackground] : Application image background does not exist, image: C:\Program Files\Altair\2023\flux\Flux\Resources\Images\FluxSupervisor\Background_Flux2D_2023_en.png
[90|1702109622203|1|WARNING ][View|View$Listener.updateNewProjectBackground] : Application image background does not exist, image: C:\Program Files\Altair\2023\flux\Flux\Resources\Images\FluxSupervisor\Background_Flux2D_2023_en.png
[93|1702109622352|1|SEVERE ][OptionsPanelsLoader|OptionsPanelsLoader.loadClassPath] : Error while loading class path, exception: class jdk.internal.loader.ClassLoaders$AppClassLoader cannot be cast to class java.net.URLClassLoader (jdk.internal.loader.ClassLoaders$AppClassLoader and java.net.URLClassLoader are in module java.base of loader 'bootstrap')
[169|1702109632209|18|WARNING ][LocalLabelManager|AbstractLocalLabelManager.getLocalLabel] : Error while getting label, using default value: Category: Supervisor Label: User Default: User Exception: Cannot find label with id User inside category Supervisor
[170|1702109632210|18|WARNING ][LocalLabelManager|AbstractLocalLabelManager.getLocalLabel] : Error while getting label, using default value: Category: Supervisor Label: Dynamic Default: Dynamic Exception: Cannot find label with id Dynamic inside category Supervisor
task__exe_stdout:
[0|1702109617730|1|INFO ][SwingApplication|Supervisor.Initialize] : FactorySupervisor 3.1.2.1146 20230704
[1|1702109617744|1|CONFIG ][Configuration|SupervisorConfiguration.<init>] : Loading configuration
[2|1702109617790|1|INFO ][FileSystemHelper|FileSystemHelper$Directory.findObjectInDirectory] : Object found in directory: From: (C:\Program Files\Altair\2023\flux\Flux\Bin\jar, F, <-) Object: C:\Program Files\Altair\2023\flux\Flux\Resources\Flux_Release.txt
[3|1702109617796|1|INFO ][FactoryHelper|FactoryHelper.getApplicationVersionFromReleaseFile] : Application version: Release file: Flux_Release.txt Version: 2023.0.0.1427 20230724
[4|1702109617809|1|INFO ][ApplicationConfiguration|ApplicationConfiguration.getApplicationConfiguration] : Application: (FluxSupervisor, 2023.0)
[5|1702109617854|1|INFO ][FileSystemHelper|FileSystemHelper$Directory.findObjectInDirectory] : Object found in directory: From: (C:\Program Files\Altair\2023\flux\Flux\Bin\jar, D, <-) Object: C:\Program Files\Altair\2023\flux\Flux\Resources
[6|1702109617855|1|INFO ][ApplicationConfiguration|SupervisorFoldersPreferences.loadFromPreferences] : Folder: (INSTALLFLUX, C:\Program Files\Altair\2023\flux\Flux)
[7|1702109618008|1|CONFIG ][SupervisorGroupPreferences|StateSupervisorPreferences.setCurrentApplicationIdentifier] : Application updated: Flux2D
[8|1702109618010|1|CONFIG ][SupervisorGroupPreferences|StateSupervisorPreferences.setCurrentDir] : Working directory updated: F:\
[9|1702109618010|1|CONFIG ][SupervisorGroupPreferences|StateSupervisorPreferences.setSelectedFile] : Selected file updated: F:\transientmagneticanalize.FLU
[10|1702109618087|1|CONFIG ][ApplicationConfiguration|ApplicationConfiguration.updateGroupPreferences] : Application configuration updated: Application: (FluxSupervisor, 2023.0) Groups: ??
[11|1702109618099|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.<init>] : Supervisor id: FluxSupervisor Version: 2023.0
[12|1702109618100|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Managed folders: ??
[13|1702109618100|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Managed folder: Key: INSTALLFLUX Path: C:\Program Files\Altair\2023\flux\Flux
[14|1702109618101|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Managed folder: Key: bin.dir Path: C:\Program Files\Altair\2023\flux\Flux\Bin
[15|1702109618102|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Managed folder: Key: dll.dir Path: C:\Program Files\Altair\2023\flux\Flux\Bin\dll
[17|1702109618102|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Managed folder: Key: dll.win64.dir Path: C:\Program Files\Altair\2023\flux\Flux\Bin\dll\win64
[20|1702109618103|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Managed folder: Key: prog.dir Path: C:\Program Files\Altair\2023\flux\Flux\Bin\prg
[22|1702109618104|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Managed folder: Key: prog.win64.dir Path: C:\Program Files\Altair\2023\flux\Flux\Bin\prg\win64
[25|1702109618106|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Managed folder: Key: docexamples.dir Path: C:\Program Files\Altair\2023\flux\Flux\DocExamples
[26|1702109618106|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Managed folder: Key: help.dir Path: C:\Program Files\Altair\2023\flux\Flux\Help
[27|1702109618106|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Managed folder: Key: howto.dir Path: C:\Program Files\Altair\2023\flux\Flux\DocExamples\HowTo
[29|1702109618106|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Managed folder: Key: overlays.dir Path: C:\Program Files\Altair\2023\flux\Flux\Overlays
[30|1702109618106|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Managed folder: Key: cedrat.dir Path: C:\Program Files\Altair\2023\flux\Flux\..
[32|1702109618107|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Managed folder: Key: resources.dir Path: C:\Program Files\Altair\2023\flux\Flux\Resources
[33|1702109618107|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Managed folder: Key: user.template.dir Path: C:\Program Files\Altair\2023\flux\Flux\User
[34|1702109618107|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Managed folder: Key: userAnt.dir Path: C:\Program Files\Altair\2023\flux\Flux\User\user_ant
[35|1702109618108|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Managed folder: Key: userRef.dir Path: C:\Program Files\Altair\2023\flux\Flux\User\user3d_ref
[36|1702109618108|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Managed folder: Key: shared.macros.dir Path: C:\Program Files\Altair\2023\flux\Flux\..\Extensions\Macros
[37|1702109618108|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Managed folder: Key: shared.overlays.dir Path: C:\Program Files\Altair\2023\flux\Flux\..\Extensions\Overlays
[38|1702109618110|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Managed folder: Key: shared.materials.dir Path: C:\Program Files\Altair\2023\flux\Flux\..\Materials
[39|1702109618111|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Managed folder: Key: supervisor.dir Path: C:\Program Files\Altair\2023\flux\Flux\Resources\Supervisor
[40|1702109618111|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Managed folder: Key: supervisor.plugin.dir Path: C:\Program Files\Altair\2023\flux\Flux\Resources\Supervisor\plug
[41|1702109618111|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Managed folder: Key: supervisor.conf.dir Path: C:\Program Files\Altair\2023\flux\Flux\Resources\Supervisor\conf
[42|1702109618112|1|CONFIG ][LocalLabelManager|AbstractResourceBundleLocalLabelManager.setBaseDir] : Directory: C:\Program Files\Altair\2023\flux\Flux\Resources\Supervisor\bundle
[43|1702109618120|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Managed folder: Key: supervisor.bundle.dir Path: C:\Program Files\Altair\2023\flux\Flux\Resources\Supervisor\bundle
[44|1702109618121|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillFolders] : Managed folder: Key: supervisor.image.dir Path: C:\Program Files\Altair\2023\flux\Flux\Resources\Images\FluxSupervisor
[45|1702109618121|1|CONFIG ][SupervisorInformations|AbstractSupervisorInformations.fillManagedApplications] : Managed applications: [FLUX2D, FLUXSKEWED, FLUX3D, FLUXPEEC]
[46|1702109618147|1|INFO ][ApplicationConfiguration|ApplicationConfiguration.getApplicationConfiguration] : Application: (Flux2D, 2023.0)
[47|1702109618187|1|CONFIG ][ApplicationConfiguration|ApplicationConfiguration.updateGroupPreferences] : Application configuration updated: Application: (Flux2D, 2023.0) Groups: ??
[48|1702109618212|1|INFO ][ApplicationConfiguration|ApplicationConfiguration.getApplicationConfiguration] : Application: (FluxSkewed, 2023.0)
[49|1702109618248|1|CONFIG ][ApplicationConfiguration|ApplicationConfiguration.updateGroupPreferences] : Application configuration updated: Application: (FluxSkewed, 2023.0) Groups: ??
[50|1702109618269|1|INFO ][ApplicationConfiguration|ApplicationConfiguration.getApplicationConfiguration] : Application: (Flux3D, 2023.0)
[51|1702109618295|1|CONFIG ][ApplicationConfiguration|ApplicationConfiguration.updateGroupPreferences] : Application configuration updated: Application: (Flux3D, 2023.0) Groups: ??
[52|1702109618318|1|INFO ][ApplicationConfiguration|ApplicationConfiguration.getApplicationConfiguration] : Application: (FluxPEEC, 2023.0)
[53|1702109618345|1|CONFIG ][ApplicationConfiguration|ApplicationConfiguration.updateGroupPreferences] : Application configuration updated: Application: (FluxPEEC, 2023.0) Groups: ??
[54|1702109618505|1|CONFIG ][Configuration|SupervisorConfiguration.updatelangage] : Defined language: en
[55|1702109618514|1|CONFIG ][FileSystemWatcher|FileSystemWatcher.Initialize] : Initializing FileSystemWatcher, use WatcherService: false
[56|1702109618517|18|CONFIG ][Supervisor|Supervisor.lambda$initializeLookAndFeel$0] : System Look & Feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
[57|1702109618812|1|INFO ][NameResolutionHelper|NameResolutionHelper.getHostname] : Detected hostname : desktop-5cqlql3
[58|1702109618812|1|CONFIG ][LicenseModel|LicenseModel.getModelProperties] : License configuration file (Windows): C:\Users\LENOVO-Z50\AppData\Local\.altair_licensing\desktop-5cqlql3\license.properties
[59|1702109618817|1|INFO ][FileSystemHelper|FileSystemHelper$Directory.findObjectInDirectory] : Object found in directory: From: (C:\Program Files\Altair\2023\flux\Flux\Bin\jar, D, <-) Object: C:\Program Files\Altair\2023\security
[60|1702109618845|1|INFO ][FileSystemHelper|FileSystemHelper$Directory.findObjectInDirectory] : Object found in directory: From: (C:\Program Files\Altair\2023\flux\Flux\Bin\jar, D, <-) Object: C:\Program Files\Altair\2023\flux\Flux\Bin
[61|1702109618961|23|INFO ][LicenseController|LicenseController.checkLicense] : Check license features
[62|1702109619306|1|INFO ][FluxVersion|FluxVersionManager.parseUserVersions] : User versions: Local: (null, 0) Shared: (null, 0)
[63|1702109619386|23|INFO ][LicenseController|LicenseController.checkLicense] : License Path Securestore
[64|1702109619386|23|INFO ][LicenseController|LicenseController.checkLicense] : License is used false
[65|1702109619386|23|INFO ][LicenseController|LicenseController.checkLicense] : License sub-system ALM_SUBSYS_LMX
[66|1702109619387|23|INFO ][LicenseController|LicenseController.checkLicense] : License Path localhost
[67|1702109619387|23|INFO ][LicenseController|LicenseController.checkLicense] : License is used false
[68|1702109619387|23|INFO ][LicenseController|LicenseController.checkLicense] : License sub-system ALM_SUBSYS_LMX
[69|1702109620076|1|INFO ][BatchSolving|BatchSolvingDialog$UserInterface.updateProjectList] : Application: Flux2D Working directory: F:\
[70|1702109620668|1|INFO ][ExampleCatalog|CatalogTreeModel.load] : Catalog: C:\Program Files\Altair\2023\flux\Flux\DocExamples
[71|1702109621815|1|INFO ][ExampleCatalog|SearchPanel.load] : Catalog: C:\Program Files\Altair\2023\flux\Flux\DocExamples
[72|1702109621876|1|INFO ][View|View$Listener.setCurrentApplication] : Application: Flux2D
[73|1702109621877|1|INFO ][ExampleCatalog|ExampleCatalog.setGroup] : Group identifier: Flux2D
[74|1702109621893|1|INFO ][ExampleCatalog|ExampleCatalog$Listener.valueChanged] : Type selected: Brushless IPM motor
[76|1702109621905|1|CONFIG ][class org.icepdf.core.pobjects.Document|Document.setDocumentOrigin] : MEMFREE: 2332091080 of 2399141888
[77|1702109621906|1|CONFIG ][class org.icepdf.core.pobjects.Document|Document.setDocumentOrigin] : LOADING: C:\Program Files\Altair\2023\flux\Flux\DocExamples/Examples2D/Basic_Examples/BrushlessIPMmotorBasic/F2D_BEX_BrushlessIPMmotorBasic_Summary_en.pdf
[78|1702109621939|1|INFO ][class org.icepdf.core.pobjects.Catalog|Catalog.<clinit>] : ICEsoft ICEpdf Core 5.1.1
[79|1702109622047|1|INFO ][View|View$Listener.entrySelected] : Catalog entry selected: CatalogEvent[TypeSelected, i=BrushlessIPMmotorBasic, l=Brushless IPM motor]
[80|1702109622053|1|INFO ][ExampleCatalog|ExampleCatalog.setStatus] : Status: Select an example and double-click on the wanted state to open the example
[81|1702109622053|1|INFO ][BatchSolving|BatchSolvingDialog$UserInterface.updateProjectList] : Application: Flux2D Working directory: F:\
[83|1702109622078|1|INFO ][WorkingDirectoryPanel|WorkingDirectoryPanel.setCurrentDirectory] : Directory: F:\
[84|1702109622081|18|INFO ][DirectoriesTree|DirectoriesTreeModel.getDirPath] : Directory: F:\
[85|1702109622084|1|INFO ][BatchSolving|BatchSolvingDialog$UserInterface.updateProjectList] : Application: Flux2D Working directory: F:\
[86|1702109622111|18|INFO ][Controller|Controller.setCurrentDirectory] : Directory: F:\
[87|1702109622119|1|CONFIG ][View|View.<init>] : Initial view set: Batch
[88|1702109622130|18|INFO ][DirectoriesTree|DirectoriesTreeModel.updateFileChildren] : Update file: File: FileNode{file=F:\, isValid=true} Children: 5
[89|1702109622195|1|INFO ][ExampleCatalog|ExampleCatalog.setStatus] : Status: Select an example and double-click on the wanted state to open the example
[91|1702109622347|1|INFO ][Supervisor|Supervisor.Run] : Supervisor starting...
[92|1702109622351|1|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.loadClassPath] : Adding option classpath: jar:file:/C:/Program Files/Altair/2023/flux/Flux/Resources/Supervisor/plug/FSPreferences.jar!/
[94|1702109622355|1|INFO ][FileSystemHelper|FileSystemHelper$Directory.findObjectInDirectory] : Object found in directory: From: (C:\Program Files\Altair\2023\flux\Flux\Bin\jar, D, <-) Object: C:\Program Files\Altair\2023\flux\Flux\Resources
[95|1702109622355|1|INFO ][ApplicationConfiguration|SupervisorFoldersPreferences.loadFromPreferences] : Folder: (INSTALLFLUX, C:\Program Files\Altair\2023\flux\Flux)
[96|1702109622365|1|CONFIG ][SupervisorGroupPreferences|StateSupervisorPreferences.setCurrentApplicationIdentifier] : Application updated: Flux2D
[97|1702109622365|1|CONFIG ][SupervisorGroupPreferences|StateSupervisorPreferences.setCurrentDir] : Working directory updated: F:\
[98|1702109622365|1|CONFIG ][SupervisorGroupPreferences|StateSupervisorPreferences.setSelectedFile] : Selected file updated: F:\transientmagneticanalize.FLU
[99|1702109622383|1|CONFIG ][ApplicationConfiguration|ApplicationConfiguration.updateGroupPreferences] : Application configuration updated: Application: (FluxSupervisor, 2023.0) Groups: 22
[100|1702109622410|1|CONFIG ][ApplicationConfiguration|ApplicationConfiguration.updateGroupPreferences] : Application configuration updated: Application: (Flux2D, 2023.0) Groups: 14
[101|1702109622426|1|CONFIG ][ApplicationConfiguration|ApplicationConfiguration.updateGroupPreferences] : Application configuration updated: Application: (FluxSkewed, 2023.0) Groups: 14
[102|1702109622447|1|CONFIG ][ApplicationConfiguration|ApplicationConfiguration.updateGroupPreferences] : Application configuration updated: Application: (Flux3D, 2023.0) Groups: 14
[103|1702109622466|1|CONFIG ][ApplicationConfiguration|ApplicationConfiguration.updateGroupPreferences] : Application configuration updated: Application: (FluxPEEC, 2023.0) Groups: 11
[104|1702109622472|1|CONFIG ][Model|Model.savePreferences] : Managed applications: 4 Synthetizers: 1
[105|1702109622474|1|CONFIG ][ApplicationConfiguration|ApplicationConfiguration.saveAll] : Application: (FluxSupervisor, 2023.0) Groups: 22
[106|1702109622475|1|CONFIG ][ApplicationConfiguration|ApplicationConfiguration.saveAll] : Application: (Flux2D, 2023.0) Groups: 14
[107|1702109622480|1|CONFIG ][ApplicationConfiguration|ApplicationConfiguration.saveAll] : Application: (FluxSkewed, 2023.0) Groups: 14
[108|1702109622484|1|CONFIG ][ApplicationConfiguration|ApplicationConfiguration.saveAll] : Application: (Flux3D, 2023.0) Groups: 14
[109|1702109622487|1|CONFIG ][ApplicationConfiguration|ApplicationConfiguration.saveAll] : Application: (FluxPEEC, 2023.0) Groups: 11
[110|1702109622490|1|CONFIG ][Configuration|SupervisorConfiguration.print] : Supervisor type : FLUX
[111|1702109622491|1|CONFIG ][Configuration|SupervisorConfiguration.print] : Type version : 2023.0.0
[112|1702109622491|1|CONFIG ][Configuration|SupervisorConfiguration.print] : Langage : ENGLISH
[113|1702109622491|1|CONFIG ][Configuration|SupervisorConfiguration.print] : Debug : false
[114|1702109622491|1|CONFIG ][Configuration|SupervisorConfiguration.print] : Drive mode : false
[115|1702109622714|18|INFO ][Supervisor|Supervisor$MainFrameManager$Listener.windowOpened] : Main frame opened
[116|1702109622714|18|CONFIG ][View|View.onShow] : Expanded help panel
[117|1702109622715|18|CONFIG ][FileSelectorUpdater|FileSelectorTableUpdater.Initialize] : Initializing FileSelectorTableUpdater
[118|1702109622715|18|INFO ][ExampleCatalog|ExampleCatalog.setGroup] : Group identifier: Flux2D
[119|1702109622720|18|INFO ][ExampleCatalog|ExampleCatalog$Listener.valueChanged] : Type selected: Brushless IPM motor
[120|1702109622724|18|CONFIG ][class org.icepdf.core.pobjects.Document|Document.setDocumentOrigin] : MEMFREE: 2314759952 of 2399141888
[121|1702109622724|18|CONFIG ][class org.icepdf.core.pobjects.Document|Document.setDocumentOrigin] : LOADING: C:\Program Files\Altair\2023\flux\Flux\DocExamples/Examples2D/Basic_Examples/BrushlessIPMmotorBasic/F2D_BEX_BrushlessIPMmotorBasic_Summary_en.pdf
[122|1702109622762|18|INFO ][View|View$Listener.entrySelected] : Catalog entry selected: CatalogEvent[TypeSelected, i=BrushlessIPMmotorBasic, l=Brushless IPM motor]
[123|1702109622956|18|INFO ][FileSystemHelper|FileSystemHelper$File.readFileToString] : File: F:\transientmagneticanalize.FLU\REPORT.TXT Encoding: windows-1252
[124|1702109622967|18|INFO ][FileSystemHelper|FileSystemHelper$File.readFileToString] : File: F:\transientmagneticanalize.FLU\persistent\comment\Comment.txt Encoding: windows-1252
[125|1702109622974|18|INFO ][FileSystemHelper|FileSystemHelper$File.writeStringToFile] : Content: 21 File: F:\transientmagneticanalize.FLU\persistent\comment\Comment.txt Encoding: windows-1252
[126|1702109622990|18|INFO ][FileSelectorTable|FileSelectorTable$UpdatingRunnable.run] : Update starting: Table: ProjectTable Current file: F:\transientmagneticanalize.FLU
[127|1702109622991|18|INFO ][FileSelectorTable|FileSelectorTable$UpdatingRunnable.run] : Update starting: Table: MruTable Current file: F:\transientmagneticanalize.FLU
[128|1702109622991|18|INFO ][FileSelectorTable|FileSelectorTable$UpdatingRunnable.run] : Update starting: Table: ScriptTable Current file: F:\transientmagneticanalize.FLU
[129|1702109622994|18|INFO ][FileSelectorTable|FileSelectorTable$UpdatingRunnable.run] : Update terminated: Table: ProjectTable Current file: F:\transientmagneticanalize.FLU
[130|1702109623034|1|INFO ][Supervisor|Supervisor.Run] : Supervisor started, time: 687
[131|1702109623055|18|INFO ][FileSelectorTable|FileSelectorTable$UpdatingRunnable.run] : Update terminated: Table: MruTable Current file: F:\transientmagneticanalize.FLU
[132|1702109623058|18|INFO ][FileSelectorTable|FileSelectorTable$UpdatingRunnable.run] : Update terminated: Table: ScriptTable Current file: F:\transientmagneticanalize.FLU
[133|1702109625148|49|INFO ][DirectoriesTree|DirectoriesTreeModel$FileModificationTask.run] : Observed file modified: C:\
[134|1702109625149|49|INFO ][DirectoriesTree|DirectoriesTreeModel$FileModificationTask.run] : Observed file modified: \
[135|1702109625150|49|INFO ][DirectoriesTree|DirectoriesTreeModel$FileModificationTask.run] : Observed file modified: F:\
[136|1702109625346|49|INFO ][DirectoriesTree|DirectoriesTreeModel$FileModificationTask.run] : Observed file modified: G:\
[137|1702109625421|18|INFO ][DirectoriesTree|DirectoriesTreeModel.updateFileChildren] : Update file: File: FileNode{file=F:\, isValid=true} Children: 5
[138|1702109625435|18|INFO ][DirectoriesTree|DirectoriesTreeModel.updateFileChildren] : Update file: File: FileNode{file=C:\, isValid=true} Children: 8
[139|1702109625447|18|INFO ][DirectoriesTree|DirectoriesTreeModel.updateFileChildren] : Update file: File: FileNode{file=G:\, isValid=true} Children: 6
[140|1702109625447|18|INFO ][DirectoriesTree|DirectoriesTreeModel.updateFileChildren] : Update file: File: FileNode{file=D:\, isValid=true} Children: 9
[141|1702109631787|18|INFO ][ActionButtonPanel|ActionButtonPanel$Listener.actionPerformed] : Button clicked: Name: OPTIONS Action: OPTIONS
[142|1702109631787|18|INFO ][View|View$Listener.actionPerformed] : Supervisor action: OPTIONS
[143|1702109631788|18|INFO ][Controller|Controller.executeAction] : Action: OPTIONS
[144|1702109631788|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Loading option tree
[145|1702109631833|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Category: Name: General Valid: true
[146|1702109631838|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Subcategory: Name: Language Valid: true Panels: [cad.fluxsupervisor.view.options.LanguagePanel]
[147|1702109631840|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Subcategory: Name: Recent files Valid: true Panels: [cad.fluxsupervisor.view.options.MruPanel]
[148|1702109631843|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Subcategory: Name: File types Valid: true Panels: [cad.fluxsupervisor.view.options.FileTypesPanel]
[149|1702109631846|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Subcategory: Name: Shortcuts Valid: true Panels: [cad.fluxsupervisor.prefs.shortcut.ShortcutPanel]
[150|1702109631848|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Subcategory: Name: Macros Valid: true Panels: [cad.fluxsupervisor.prefs.macro.MacroPanel]
[151|1702109631850|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Category: Name: System Valid: true
[152|1702109631855|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Subcategory: Name: Memory Valid: true Panels: [cad.fluxsupervisor.view.options.MemoryPanel]
[153|1702109631857|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Subcategory: Name: Parallel computing Valid: true Panels: [cad.fluxsupervisor.view.options.ParallelComputingPanel]
[154|1702109631859|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Subcategory: Name: Graphic mode Valid: true Panels: [cad.fluxsupervisor.view.options.DisplayPanel]
[155|1702109631861|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Subcategory: Name: Network ports Valid: true Panels: [cad.fluxsupervisor.view.options.NetworkPortsPanel]
[156|1702109631864|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Subcategory: Name: Debug Valid: true Panels: [cad.fluxsupervisor.view.options.DebugPanel]
[157|1702109631866|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Subcategory: Name: User mode Valid: true Panels: [cad.fluxsupervisor.view.options.UserModePanel]
[158|1702109631867|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Category: Name: Access paths Valid: true
[159|1702109631869|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Subcategory: Name: User version Valid: true Panels: [cad.fluxsupervisor.view.options.UserVersionDirectoryPanel, cad.fluxsupervisor.view.options.UserVersionChoicePanel]
[160|1702109631871|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Subcategory: Name: Python Valid: true Panels: [cad.fluxsupervisor.view.options.PythonPanel]
[161|1702109631873|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Subcategory: Name: Materials Valid: true Panels: [cad.fluxsupervisor.view.options.MaterialsPanel]
[162|1702109631874|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Subcategory: Name: Extensions Valid: true Panels: [cad.fluxsupervisor.view.options.ExtensionsPanel]
[163|1702109631876|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Subcategory: Name: Coupled software Valid: true Panels: [cad.fluxsupervisor.view.options.CoSimulationPanel]
[164|1702109631877|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Category: Name: Flux Valid: true
[165|1702109631881|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Subcategory: Name: Sketcher / Modeler Valid: true Panels: [cad.fluxsupervisor.prefs.sketcher.SketcherPanel, cad.fluxsupervisor.prefs.modeler.ModelerPanel]
[166|1702109631883|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Subcategory: Name: Geometric construction Valid: true Panels: [cad.fluxsupervisor.prefs.geometry.GeometryPanel]
[167|1702109631885|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Subcategory: Name: Meshing generation Valid: true Panels: [cad.fluxsupervisor.prefs.mesh.MeshPanel]
[168|1702109631887|18|INFO ][OptionsPanelsLoader|OptionsPanelsLoader.load] : Subcategory: Name: Solving Valid: true Panels: [cad.fluxsupervisor.prefs.resolution.ResolutionPanel]
[171|1702109632323|18|INFO ][OptionPanel|UserVersionChoicePanel$ChoicePanel.initializePanelData] : Using selected version: Standard
[172|1702109650042|18|INFO ][Supervisor|Supervisor$MainFrameManager$Listener.windowClosing] : Main frame closing
[173|1702109650043|18|INFO ][Controller|Controller.executeAction] : Action: QUIT
[174|1702109650077|18|INFO ][Supervisor|Supervisor$MainFrameManager$Listener.windowClosed] : Main frame closed
[175|1702109650080|18|CONFIG ][FileSystemWatcher|FileSystemWatcher.Terminate] : Terminating FileSystemWatcher
Hello David,
Unfortunately it is not easy in this case understand the problem and help you without the model.
Seeing the error it could be a problem with Flux regarding the closure of child processes, but we have to go in depth.
Could you open a ticket in the support section and share the Flux and the HyperStudy models? Which versions and OS system are you using?Please share these information in the ticket, it will help us to find the problem.
Best regards,
Letizia
Dear Letizia
thanks for your reply...
The problem was solved, in fact, the problem was in the addressing path of flux software for hyperstudy, in other words, the address: (C:\Program Files\Altair\2022\flux\Flux\Bin\prg\win64\FluxSupervisor.exe) is wrong.
The correct address is written below, instead of using fluxsupervisor, flux should be used.
C:\Program Files\Altair\2022\flux\Flux\Bin\prg\win64\Flux.exe
Hello David,
You are right that the solver script should point to flux.exe, and not to FluxSupervisor.
Note that regarding FluxMotor, the path should point to FluxMotors.exe (I see on your image FluxMotor.exe without the last "s" which is not correct, that is why HyperStudy display it in orange font).
I would like to add the information below in case it can be helpful:
1) HyperStudy automatically populates the solvers which are installed in the location by default. If Flux is installed in Altair\2023 along with HyperStudy, the Flux and FluxMotor solver scripts will be added automatically and will appear in grey in the Register Solver script window. Maybe you have installed Flux afterwards!?
2) In case you add by yourself a solver script (you can always do it), HyperStudy provides guidance about the exe required. By using this, you will be safe to define inconsistent path.
Please look at the blog below:
HyperStudy Tips and Tricks: #4 - Registering Solver Scripts with Solver Path Guidance
https://community.altair.com/community?id=community_blog&sys_id=e484a0a51b03b4d0507ca6442a4bcb73
Nice day!
Diana - Altair support team
Hello David,
Best regards,
Letizia
