Format for Equation-Defined Force
Altair Forum User
Altair Forum User
I'm trying to simulate a bearing load on a cylindrical hole. I've defined a cylindrical coordinate system in the hole and associated a semi-circles's worth of nodes with it (although I am unable to use these particular nodes later when I define the way the load acts, strange). I want to model the load using a cosine function so I can maximize the effective force along the line of application. What kind of syntax and definition of variables is Hypermesh looking for when I develop an equation to represent a distributed load? I'm using Nastran for analysis FYI.
Thanks,
Brandon Amat
University of Michigan Mechanical Engineering '14
Michigan Baja Racing
  • Altair Forum User
    Altair Forum User
    edited November 2012
    a very simple equation as example (Analysis->Force->nodes->switch to equation)
    type in: cos(x)
    So you can define the magnitude of the forces as cos(xlocation)...
    Mario
  • Altair Forum User
    Altair Forum User
    edited September 2015
    So which means 'sin(x)' x- magnitude, will be my  equation for my sinusoidal bearing load?
  • Altair Forum User
    Altair Forum User
    When I created an equation and applied to particular nodes but its taking as a unit load only.
    How can we I give a loading equation ?
    Can you please replay for my doubt?
  • tinh
    tinh Altair Community Member
    if you type 'sin(x)' in magnitude then it is unit load only
    you should type in magnitude as '10*sin(x)' số load is tên time
    image/emoticons/default_biggrin.png' alt=':D' srcset='/emoticons/biggrin@2x.png 2x' width='20' height='20'>
