Hello friends, is it possible to install a package like Pandas in the coding environment of Altair Flux and import it into the code? Please give a full explanation... Thank you for your help.
Hello David,
Since the usage of third-party library with Flux has not been qualified by Altair, Flux support is not responsiblefor maintaining or fixing bugs related to the integration.In particular there are known limitations / issues when trying to use Panda in Flux, so it is strongly recommended use third-party library externally.Please check in the list of the "How to" documents, you can find some useful general documents related to the integration with third-party library."How to Use External Jython Classes in Flux?"https://help.altair.com/flux/Flux/DocExamples/HowTo/English/HowTo_UseExternalJythonClassesInFlux.pdfAnd eventually "How to Experiment with NumPy in Flux?"https://help.altair.com/2023/flux/flux/docexamples/howto/english/howto_experimentwithnumpyinflux.pdf
Best regards,
Letizia
