2d contact between surface edges in a 2d model
Hi rodrigomierh
Are you using Nodes for defining master in your contact model?
if yes, please include elements in master instead of node and try.
0 -
I deleted the sets and interfaces I had and created new ones with elements for both master and slave and now it is working. Thanks.
0 -
Hi @ahkrit
Looks like the way the contact surface element selected is wrong.
Select the elements which come in contact. The from face elements may not come in contact but the bottom elements of yellow component and top elements of blue components come in contact upon application of load.
0 -
hi. i just found the option free edges. with it it works better. but somehow with the contact parameters i can not solve the contact with zero distance between the components. I got always an other displacement at contactpoints. What can be the problem? A displacement with the blue loadcollector at the yellow component is defined.
Thanks!
0 -
Hi ahkrit,
Sorry, i'm not able to understand your problem. Please can you explain it clearly. Also, if possible please share your model.
Thank you
