property and material cards for rigid elements
BLOCK FREE FORMAT
.. STARTER RUNNING ON 4 THREADS
.. CONTROL VARIABLES
.. UNITS SYSTEM
.. MATERIALS
.. NODES
.. PROPERTIES
ERROR ID : 178
** ERROR IN PART DEFINITION (PROPERTY)
DESCRIPTION :
-- PART ID : 7
-- PART TITLE : rigids
PROPERTY ID=0 DOES NOT EXIST
ERROR ID : 179
** ERROR IN PART DEFINITION (MATERIAL)
DESCRIPTION :
-- PART ID : 7
MATERIAL ID=0 DOES NOT EXIST
.. 3D SOLID ELEMENTS
.. 3D SHELL ELEMENTS
.. 3D BEAM ELEMENTS
.. 3D TRIANGULAR SHELL ELEMENTS
.. SUBSETS
.. ELEMENT GROUPS
.. PART GROUPS
.. NODE GROUP
.. INITIAL VELOCITIES
.. DOMAIN DECOMPOSITION
.. ELEMENT GROUPS
.. RIGID WALLS
.. ELEMENT BUFFER INITIALIZATION
.. GEOMETRY PLOT FILE
.. ERROR ==> NO RESTART FILE
ERROR TERMINATION
2 ERROR(S)
1 WARNING(S)
PLEASE CHECK LISTING FILE FOR FURTHER DETAILS
==== End of solver screen output ====
==== Job completed ====
In Radioss we should not provide any material and property to Rigid element(Rbody).
If you are considering any component and part as rigid then assign MAT1 cards and provide linear elastic property like E, NU & RHo.
Regards
Rahul R
0 -
i done same but error remains for property
0 -
Please define property for the same Rbody.
Regards
Rahul R
0 -
Hi Pankaj,
Have you made the part/component Rigid by card editing the PART and checking the box next to Rigid?
0 -
actually no rigid card is found instead of part
0 -
@Rahul R: is it the same for the optistrut solver also....should i not define material or properties for the Rigids while solving in optistrut also......or should i create a seperate prop for rigids as 1D element prop and assign materials?......
0 -
thanks @Prakash Pagadala
