Dear Customer Service,
I tried to use in Hyperview Comand window the downloaded tcl macro named as Query for Node and Elements (name of the downloaded file 39457604_qury_id.tcl).
I tried to test this file on a small optistuch h3d file. The stress was comupted by the OUTPUT2 option in the corner nodes).
Unfortunately I have got a lot of errors after the execution of the source command.  The new User interface window has appeared in the Hyperview surface but any execution aborted.
What could be wrong?
Basically I would like to write a script which shows the principal stess vectors in a selected node. Do you have an existing solution for that problem?
Thank you for your help and best regards.
Dr. Gyorgy Toth
Knorr-Bremse Budapest
