HyperView Batch Mode
User: "Altair Forum User"
Updated by Altair Forum User
Hello everyone,
I would like to launch HyperView in batch mode but I don't find what I want in the help pages.
I'm looking for options in order to launch HyperView specifying the template file and the result file to launch and also run a TCL script.
Maybe someone know how to do that or tell me where to find the awnsers ...
Thanks a lot,
1 - 4 of 41
    OP
    You can run tcl script in batch mode, and then evertyhing can be done using tcl scripting
    Regards
    Maciek
    OP
    Regards
    Maciek
    Hello maciejhebda,
    Thank you for your help ! Yes it can be a solution but can you tell me how to write it in TCL ?
    Thanks a lot !
    OP
    Hi nhykola,
    you find some advises in the manual of HW.
    Otherwise here is some short example - the comments are unfortunately in german.
    The Example opens a h3d file and create a derived load case with the first three eigenvalues of a buckling analysis. After that the script export the contour of the defomed model into a stl File.
    set BatchOrdnerPfad $::env(BatchOrdnerPfad)
    set Geometrie $::env(Geometrie)
    #set BatchOrdnerPfad 'C:\\Simulation\\AutoTool'
    #set Geometrie 'H_20-l_10-psi_90-T_0-eta_240-rho_72111111'
    hwi GetSessionHandle Session1
    Session1 GetProjectHandle Project1
    Project1 GetPageHandle Page1 1
    Page1 GetWindowHandle Win1 1
    Win1 GetClientHandle Client1
    # Model wird geladen
    Client1 AddModel '$BatchOrdnerPfad/$Geometrie/Beulen/$Geometrie.h3d'
    Client1 GetModelHandle Model1 1
    # Ergebnisse (LoadCases) zum Model werden geladen
    Model1 SetResult '$BatchOrdnerPfad/$Geometrie/Beulen/$Geometrie.h3d'
    Model1 GetResultCtrlHandle Result1
    Result1 GetScaleCtrlHandle Scale1
    # Scale Faktor des gesamten Models. Jeweils in die drei Achsrichtungen
    # !!! SKALIERUNG MUSS ALS ERSTES VORGENOMMEN WERDEN, DA ANDERNFALLS FEHLER AUFTRETEN !!!
    Scale1 SetScale '0.1 0.1 0.1'
    Scale1 ReleaseHandle
    # Neuer (Derived-) Subcase wird eingefügt
    Result1 AddSubcase 'BeulMod'
    Result1 GetSubcaseHandle Sub1 3
    # SubCase Typ = Lineare Superposition
    Sub1 SetDerivedType 'superposition'
    #Anzahl der Beulmoden, welche Superponiert werden 0,1,2 (3 Stück)
    Sub1 AppendSimulation 2 0
    Sub1 AppendSimulation 2 1
    Sub1 AppendSimulation 2 2
    # Skalierungsfaktor der jeweiligen Simulation (hier alle einfach)
    Sub1 SetSimulationScaleFactor 0 1
    Sub1 SetSimulationScaleFactor 1 1
    Sub1 SetSimulationScaleFactor 2 1
    Sub1 ReleaseHandle
    Result1 SetCurrentSubcase '3'
    Model1 SetMeshMode meshlines
    # Export der Contour in eine stl-Datei
    Result1 GetIsoValueCtrlHandle IsoValue1
    IsoValue1 ExportSTL '$BatchOrdnerPfad/Geometrien/$Geometrie.stl'
    IsoValue1 ReleaseHandle
    # Freigabe aller Handler
    Result1 ReleaseHandle
    Model1 ReleaseHandle
    Client1 ReleaseHandle
    Win1 ReleaseHandle
    Page1 ReleaseHandle
    Project1 ReleaseHandle
    Session1 ReleaseHandle
    # Befehl um das Skript im Batch Modus auszuführen!
    # 'C:\Program Files\Altair\13.0\hw\bin\win64\hw.exe' /clientconfig hwpost.dat -b -tcl C:\Simulation\AutoTool\Python\Hv2stl.tcl
    User: "Merula_20758"
    Altair Community Member
    Updated by Merula_20758
    Hi there,
    thanks for that script.
    Unfortunately I cannot see how to add a second result file. I want to create an envelope loadstep of all topology optimization load steps. These are saved into separate files. (s1,s2,...)
    There is the option in hyperview to add a second result file to generate a derived loadstep. But I cannot find any in the help (e.g. append Simulations only allows ids, not paths to files).
    Any ideas?
    Thanks in advance and best regards,
    Merula
