Hello all,
I am relatively new to hypermesh and I have some difficulties to make my model run.
My model is a solid model of an anisotropic material. I have conciously checked the material orientation of the different components thanks to a TCL script that I've been given and all the elements are oriented how they should be.
However, when defining the material property, I don't see what I am supposed to do. I have selected the Orientation, UseOrientationId option, which set the value to 0. However, when running the model, it crashes because of this error:
***ERROR: PARAMETER ORIENTAT MUST HAVE A VALUE
LINE IMAGE: *SOLID SECTION, ELSET=HMprop_Resin, ORIENTATION = ,
MATERIAL=Central adhesive
*SOLID SECTION, ELSET=HMprop_Resin, ORIENTATION = , MATERIAL=Central adhesive
So where should I set that the orientation is the mesh orientation?
Thanks in advance,
