Hello Everybody, I´m a new user of scripting for hypermesh. I would like if someone here knows if it is possible to display a button while a script is running in order to let the user the chance for stop the script. Thank a lot.
If your script run for long time due to hypermesh command (you feel hm freezing), stop it by holding down RMB on graphic area
If your script run for long time due to some loops (ex: for..., while,...), stop it by a break, example: if {::stop} {break} and the button will set ::stop = 1 when clicked
remember to 'update' GUI within loops otherwise the button will frozen also and you cannot activate it
Hi, If your script run for long time due to hypermesh command (you feel hm freezing), stop it by holding down RMB on graphic area If your script run for long time due to some loops (ex: for..., while,...), stop it by a break, example: if {::stop} {break} and the button will set ::stop = 1 when clicked remember to 'update' GUI within loops otherwise the button will frozen also and you cannot activate it
thank you
