how can i check the weight of my model?
Materialproperty [ROH] is assigned.
Best regards
BeMa
You need to use Tool > Mass Calc
thank you
how can i check the weight of the final design proposal?
Beatrice
The total mass at each iteration of an optimization is output to the .out file
thank you!
Hi! I cannot see the mass of my resulting (final iteration) design space. I see the mass of the volume fraction response, but I also don't see that this response changes through iterations. I made a constraint on volume fraction and put an upper bound to 0.5 of the initial volume. From what I read on one of your tutorials, this means that the solver is constrained to go under this value of volume fraction.
How can I measure the mass of the final iteration? And is it right that the volume fraction is not changing? I will attach my output file. Thank you for your help
I HAVE 2014 V. I HAVE NOT FOUND THE OPTION OF MASS CALCULATION IN TOOL
Please find the attached image.
