Altair RISE
Nominate Yourself Now!
contact problems between two components
User: "Altair Forum User"
Updated by Altair Forum User
I have a problem by creating a contact surface between two components.
I wanted to realize a stick contact, but only a few nodes interact, so at these nodes massive peak of stress appears.
I tried to change change the parameters, so i reduced the mesh-size and tried a friction-contact with a high coefficient between the two parts. The result was the same.
After this I changed the parameters fo Freeze and MOrient = Normal.
The result was way better, but a peak with high stress appeared at the end of the contact surface.
Moreover I tried to expand the contact surface.
You can see the results in the pictures, which I attached to this post.
Also I added the .hm and the .h3d file.
Can you tell me, where i made a mistake or how I can fix the problem?
Thank you very much in advance for your help.
Best regards
M. Herrmann
