Hi i have to study the displacement on a tube. I need 3d mesh because i have to choose the material. I have as material MAT1 and as property PSOLID (i don't want PSHELL). The problem is that when i selected the surfaces with 'bounding surfaces' it doesn't transform in solid because ' no closed volume found'.
This is one image of the tube.
What else can i do?
Thank you very much
