After run a batchmesher config, submit the job, it just show the erroe as below in Evenlog
Jul 14 22:09:55 : Error: Model xxx.prt can not be processed because
Jul 14 22:09:55 : file .\xxx.prt is not accessible.
But actually all the UG parts are in the working directly. If I mesh them manually it is ok. but with the config file, it failed.
And the batchmesher interface show the message as title.
do you have any idear about this error?
Thanks.
