I am new to Hypermesh and I had a few questions.
I have a custom geometry that is currently stored in a text file as a series of points along a surface. The geometry is the surface of a custom-designed balloon that has non-analytical curvature (i.e. it cannot be represented by an analytical function of x,y,z). We have solve for the points along the surface using another calculation program and we have output the coordinates of the surface in cartesian coordinates so that we can import them into another program to actually create the surface to then run simulations on.
Is there a way to import a list of coordinates in ascii format to create a surface from those points? Or otherwise, can I import a section of the list of points to create the lines along surface (from pole to pole) and then interpolate the surface from the lines?
I have the pole-to-pole lines in another program (Comsol) but when I try to save the geometry as Parasolid files, I cannot import them with Hypermesh. I'm not sure if it is a problem writing the file with Comsol or reading the file with Hypermesh.
Thanks,
Carl
