Hello ,
I would like to know whether there will be normals/orientation for a surface as we have for elements in HM-12.
Thanks,
Abhijith
Sure, there is
surface normal is very important when you extract middle surface or offset a surface
you can display / reverse surface normal in panel surface edit/offset
Usually when we locally alter the mesh ,the orientation/normals of elements change at few places.
In ANSA i have learnt recently that if the surface orientation is same the elements orientation does not change even if changes are made to the mesh locally.
do we have an option in HM as well.
Hello
I am not sure how you change elements locally, if you create element by F6/create then normal is possible different
Anyway you should unify normals before exporting model
Well i meant to say i delete some elements near the hole/washer region or i go for ruled option and complete the mesh.
at these times few elements orientation would have changed. then i need to change the normals manually.
My question was ......in ANSA once the normals of the surface is fixed whatever changes( elements for example) we make , the normals of elements doesnt change it adheres to the surface on which the element changes were made.
but in HM its not tat case.
Yes, it is
if you remesh the elements by F12/elems then normals may not change
but if you modify the mesh by ruled/drag/spin/... then these action is not related to original surface so elements normal no longer specified by surface normal
so it is different from ansa perhaps
Yes, in ANSA whatever may be the changes w.r.t elements made , the normals of elements doesnt change coz the it adheres to orientation/normals made to the surface on which the elements are lying
Thanks that answers my query .
I created a mesh and adjusted normal's in same color. So now in my modal the normal vector is towards Z-axis.
So what will be the difference If I applied load in Z-axis and If i applied load in -Z-axis?
I created a mesh and adjusted normal's in same color. So now in my modal the normal vector is towards Z-axis. So what will be the difference If I applied load in Z-axis and If i applied load in -Z-axis?
For shell elements, the modification of element normal has an impact on pressure applied on this element.
If your load is nodal forces, element normal does not have any impact on it.
