Durability Analysis
Hello All,
I want to do the durability analysis of one model using Durability Director of Hyperworks (version 10.1). Unfortunately, I am stuck at the very start - I can't locate the Durability Director in MotionView (as suggested in the tutoial). So I would greatly appreciate if anyone could tell me how to open the durability director for the durability analysis. Many thanks in advance!
Best Regards,
Harpreet
Durability Director has been released in HW10 with Update SA1-601 (Dec 2010). HW10.1 does not contain this update. This is probably the reason why you do not find it in 10.1. If you do not have access anymore to a HW10 FlexLM license, you probably have to wait until MotionView 11.0 will be released.
0 -
It is good to share.
0 -
hi.. thank you for sharing. one raise up the question and a good answer. thank you. i'll be sticking to some updates.
0 -
Thank you for this article. That’s all I can say. You most definitely have made this post into something special. You clearly know what you are doing, you’ve covered so many bases.Thanks!
0 -
Hello Harpreet,
I had the same requirement sometime back. Although, Durability Director is not 'directly' supported in v10.1, since this is a HyperWorks Process Manager application anyway, Altair folks showed me how I can use Durability Director in HW 10.1
Please give me your e-mail id and I'll forward the instructions. I worked with Keshav (keshavs@altair.com) who helped me with this. If you wish, you can also contact him directly.
Also, I'm just curious - for what application are you trying to use Durability Director? What's the use case?
Cheers,
Dynamic Guy
