I imported a geometry from ug to hypermesh and generated the mid-surface
the mid surface generated is torn at a few points but this issue can easily be resolved by merging nodes.
so i went to geom>point edit>replace now when i try to select the moved point, it just isn't getting picked by hypermesh
same problem occurs when i try to merge the edges and also when i try through quick edit
I even reinstalled hypermesh but still the problem persists.
I opened the same file on a friend's system and it was working fine..
can anyone help me out??
