how to group element inside a closed surface volume
User: "Altair Forum User"
Updated by Altair Forum User
Hi!
I wonder if it's possible in hypermesh
to select elements inside a closed surface volume (e.g. stl surface) into a new component?
For example, there is a meshed cubic, then I want to select some elements that is inside a enclosed spherical surface?
Thanks for your attention.
BR,
Xiaogai Li
1 - 3 of 31
    OP
    Hi!
    BR,
    Xiaogai Li
    As per I understood you want to move element from the cubic surface to spherical surface ,for this go to organise subpanel you can find this in the collectors toolbar.In that select elements >select elements and click on move image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'> thats all image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
    OP
    Hi! Thanks for your suggestion.
    But sorry I might not express myself clearly.
    The cubic is meshed with solid elements (tetra or hex elements), and I want to select the solid elements that is inside a closed volume defined by a stl surface.
    Is there any way to do the above?
    Of course my problem is much more complex geometry than this.
    Thanks.
    BR,
    Xiaogai Li
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi there,
    there is too much elems that you was boring to select all of them????
    I think you can do like these
    1) make shell (faces) for the solid elems
    2) select shell elems 'by collector' ^faces
    3) continue selecting 'by adjacent', you will get the outer solid elements
    4) now select by 'reverse' you will get the solid elements inside the body
    goodluck, man
    image/emoticons/default_biggrin.png' alt=':D' srcset='/emoticons/biggrin@2x.png 2x' width='20' height='20'>
    rgds,
