TABLED1 data entry
Please help me on TABLED1 entries. I am not able to understand how to assign values in this table (help is not clear). If I want to assign random values can I do it or not. Say in Element flux I want to enter values as
for time = 0 sec value is 4.2
for time = 4 sec value is 0
for time = 4.5 sec value is 4.2
for time = 8 sec value is 0
for time = 8.5 sec value is 4.2. and so on to say 16 sec or 24 sec or more.
Can I input these types of random values to TABLED1 Card or not.
From Help:
Discontinuities may be specified between any two points except the two starting points or two end points. For example, in Figure 1 discontinuities are allowed only between points x2 through x7. Also, if y is evaluated at a discontinuity, the average value of y is used. In Figure 1, the value of y at x = x3 is y = (y3+y4)/2.
3.At least one continuation entry must be specified.
Can you make changes to your table as per the above and check if you can get results you desired?
0 -
Thanks for the reply sir. I have to apply a heat flux as (Need to apply this practically as per the problem statement)
at time = 0 sec, Heat Flux = 4.2e6 W/m2
at time = 4 sec, Heat Flux = 0 W/m2
at time = 45 sec, Heat Flux = 0 W/m2
1. What I have entered in TABLED1 is
x1 = 0, y1 = 1 (Linear)
x2 = 4, y2 = 0 (Linear)
x3 = 45, y3 = 0 (Linear)
After I entered these I didn't get the right results.
2. And when I give values as below still didn't get the correct results:
x1 = 0, y1 = 4.2e6
x2 = 4, y2 = 0
x3 =45, y3 = 0
Maybe there is something else wrong in my model but I first want to conform this whether this is correct or not the above two tables which I input.
Please give your inputs
0 -
can you make the following changes and check if you are able to get results?
x1=0 y1=4.2e6
x2=2 y2=4.2e6
x3=4 y3=2
x4=20 y4=0
x5= 40 y5=0
x6=45 y6=0
0 -
I have tried the above values it didnt work out sir. The values of temperature are in 9.99e5 ranges. May be something is terribly wrong in my problem but I have used the same procedure as given in tutorial OS-1090. Please suggest me something. Working on brake disc transient thermal behaviour. Boundary condition are ambient at 22 degree. Covection through disc surface. And heat flux on both discs. I can share model with you if you want.
0 -
Hi Shanky,
can you share your model?
Please use the dropbox link in my signature to share the model.
0 -
I have sent you the model files Sir. From- ishan.aggarwal1987@gmail.com
0 -
Thank you for sharing the files.
I will investigate and get back to you ASAP /emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
0 -
Hi....
if i want to do pretension for 1st 0-20 sec and next 20-100 sec for modal analysis then how i should define the table and load step?
Please help in this regards.
thank you
0 -
Hi Prajwal,
Could you please let me know what is the objective of such setup?
Modal analysis is not time dependent.
0 -
Hi Sir,
I was simply trying different scenario..
can we control pretension in model?(like time dependent)
if I add time in pretension, Is that the model become Nonlinear?
Thank you
0 -
Please check this tutorial:
RD-T: 3510 Cantilever Beam with Bolt Pretensioner
0 -
hello admins
I use materialss have frequency-dependent properties
I would like to enter E, G, netar data as .txt
but got error
can you help me
0 -
Mr @RAHUL
I have encountered TABLED1 entering error
' Discontinuities are not allowed at TABLEM1 endpoints.'
0 -
As the error clearly indicates there are discontinuities in the table.I presume you have two different load values at the same time/frequency which is not allowed.
Please check the time data and filter it out to a valid input. If x is identical, you get an error.
0 -
I work on frequency domain and I have not data on time domain
when data on convert to any plot I cannot see any discontinuities
on the other hand, I have only material datas for frequency dependent materials which you know0 -
Can you share the Tablem1 end points?
0 -
at 1000 Hz 232E5 for E (young Modulus)
at 1000 Hz 2386233 for G (Shear Modulus)
