We all know that hyperwork is unitless. But then i face an inconsistency in importing my geometry into hypermesh. I import same geometry, one in the form of Nx part file, another one is in parasolid, both with exactly same geometry. The geometry of part file after imported into hypermesh will have exact the same size as in Nx( let say the length is 100mm in Nx, the length after imported into hypermesh is 100). But if i import the parasolid geometry with length of 100mm into hypermesh, the length would appear as 0.1 instead of 100.
How can i solve this inconsistency? It is important for me to standarise everything without using the scaling factor as i need to automate my process. I would use both Simlab and Batchmesher in my process, the inconsistency is a very big problem.
