below is the command lines that i am using for the same.I am just a beginner.This is FYI. Correct me if something is wrong
*createmarkpanel elements 1 'Select penta elements to combine';
set d [hm_getmark elements 1];
hm_createmark elements 1 $d;
*findmark elements 1 1 0 nodes 0 2
set nodelist [hm_getmark nodes 2];
hm_createmark nodes 2 $nodelist; ------------->woking fine till here
*createlist nodes 2 $nodelist;
*createelement 208 1 2 0;
*deletemark $d
after the 4th line from bottom(i.e..last 3 lines), I don't know what is the issue. The error line while execution reads 'More nodes should be selected to build the element'.
Till 4th line from the bottom, the commands are to save the nodes of 2 penta elements(8 nodes) and marking it. I tried creating quad elemet also using *createelement 104 1 2 0;
I was easily able to create mass element on the 8 nodes saved replacing the last 3 lines with *masselement(2,0,'',0).
That means to me something wrong with my last 3 lines of command.
