i need the tcl code to perform a advanced query after applying contour
There're some examples about query control using HyperView's poIQueryCtrl class.
Maybe these will help you out:
Example #1
This following example script requires that you first load a model:
# Get Active model handle
::post::GetActiveModelHandle m
# Create an element selection set and add element 100,
# then add adjacent
m GetSelectionSetHandle eset [m AddSelectionSet element]
eset Add 'id == 100'
eset Add adjacent
# Get a query control, set the selection set, then define
# the query. The query consists of a dot notation containing
# DATASOURCE.FIELD. Data sources can be listed by calling
# GetDataSourceList, properties for a particular data source
# can be listed by calling GetDataSourceFieldList and passing
# the data source to list fields for:
# qc GetDataSourceList returns 'node element component ...'
# qc GetDataSourceFieldList element returns 'id config compid ...'
m GetQueryCtrlHandle qc
qc SetSelectionSet [eset GetID]
qc SetQuery 'element.id element.connectivity'
# once the query has been set and the selection set has been assigned
# to the query control, the data can be extracted by retrieving an iterator
# and cycling through all the items in the set and calling GetDataList.
qc GetIteratorHandle qciter
for {qciter First} {[qciter Valid]} {qciter Next} {
puts [qciter GetDataList]
# Release all handles
qciter ReleaseHandle
qc ReleaseHandle
eset ReleaseHandle
m ReleaseHandle
Example #2
The following example script will print the raw data of a displacement data type for all nodes:
hwi OpenStack
set t [::post::GetT]
::post::GetActiveModelHandle m$t
m$t GetSelectionSetHandle s$t [m$t AddSelectionSet node]
s$t Add all
m$t GetQueryCtrlHandle q$t
q$t SetSelectionSet [s$t GetID]
q$t SetDataSourceProperty result datatype Displacement;
q$t SetQuery 'node.id result.value'
q$t GetIteratorHandle i$t;
for { i$t First } { [i$t Valid] } { i$t Next } {
puts 'data is [i$t GetDataList]'
hwi CloseStack
hi,
In the above set of scripts how to get the component ID of the part which is showing maximum nodal displacement?
Thanks in advance
