Is there a way to manually set the CID field of the CBUSH card in HyperMesh?
Without this feature the coordinate system has to be inserted into the analysis deck manually. This is impractical for large models.
hi Brett
what do you mean 'manually'?
can't you click on 'CID' and select coordinate system?
this card data typed 'entity' so you can select it directly on graphic area
