Can I model a revolute joint with HyperMesh? If so, how to do this? Does any tutorial show this?
Hi Ariane,
Please go through http://www.altairuniversity.com/learning-library/10-procedure-to-create-kjoint2-in-radioss/ which shows creating a revolute joint in HyperMesh RADIOSS interface using /PROP/TYPE45 (KJOINT2).
Another option to model joints in RADIOSS is to use a /PROP/TYPE8 spring. Provide high stiffness to all degrees of freedom those are fixed and zero stiffness in the direction which you want to be free. The model file attached for your reference.
Thanks! But I'm working with OptiStruct, Is the procedure the same?
Hi @Ariane Rebelato
You can use BEAM (PBEAM and remove DoF using PA, PB)
i want revolute joint without any movement .ie. only to transfer load ?
A joint is used to allow for a relative movement between components. If the purpose is only to transfer loads then you model with connectors or rigids for that.
Hi Ariane, Please go through http://www.altairuniversity.com/learning-library/10-procedure-to-create-kjoint2-in-radioss/ which shows creating a revolute joint in HyperMesh RADIOSS interface using /PROP/TYPE45 (KJOINT2). Another option to model joints in RADIOSS is to use a /PROP/TYPE8 spring. Provide high stiffness to all degrees of freedom those are fixed and zero stiffness in the direction which you want to be free. The model file attached for your reference.
Can I have its hm file ?
Please find the file.
HI @Ariane Rebelato
I am doing revolute joints practice.
Can I ask you how do you finally set the joints?
