Hello at all,
i made an analysis of a wireframe of a formula student car and created some loadcases for buckling.
In HyperView there are some negative and some positive magnitudes for F (for buckling mode 4).
I´m quite sure that this is the factor λ.
So i thought if λ>0 (positiv) there is no buckling and if λ<0 (negativ) then there is buckling.
Now i noticed, in every case where are the negative magnitudes, then a tension rod is buckling or deforming and when there is a positive magnitude then a pressure bar is buckling. I thought only rods/bars under pressure can buckle.
My problem is to interpret these cases.
Could it be that the buckling of a tension rod is a kind of neckling???
And when it is a kind of neckling, how to give an interpretation of the buckling?
Why are tension rods are deforming in my buckling analysis?
I hope you can help me.
Rizzo
