Not able to open .k files in hypermesh
I have meshed a model in hypermesh and I exported it to Ls-dyna by using .k file. That worked all fine. But as I wanted to make some modifications in the mesh, I am not able to import the k file back into hyperworks. I tried saving for same versions of Ls-dyna from both the ends. It did not help.
If I try to import the same file which I just exported from hypermesh, even that file is not being read.
The message in the bottom says 'The file being opened for reading does not exist'. Screenshot attached. I have made sure that I am using the correct path of the file I want to open.
But this ' file does not exist error' shows up for many cases, even when I try to check element quality or even when I open the hypermesh default screen. Screenshot attached. (2nd)What could be the problem?
hi,
try
0 -
Thank you. It worked. There was some issue with my user profile and the shortcut I had created for hm.
