People who used ANSYS will be knowing about the Symmetry BC there.
Is it possible to do the same in hyperworks also?
If you have to give both symmetry constraints and fixed constraints can we give it in the same load collector?
Hi Natarajan,
although I do not use Ansys, but constraints can be entered in Hypermesh as in other preferences. (i think so)
Symmetry is to be set by hand, but that's simply. And of course you can mix different types or DOFs at the same collector.
At the end, the symmetry bc's are fixed bc's...
Mario
