Multi point Constraint
Hi Youssef,
MPC are used to define a relationship between a set of nodes to dependent node (Equation).
For instance, you have a dependent node and you want the X displacement of the dependent node equal to sum of half of X displacement of one of the independent node and twice of Y displacement of another independent node.
in such a case you can use MPC.
0 -
Perhaps this webinar on MPC will help, - http://www.altairhyperworks.de/html/de-DE/BestPractice_Recordings/2011/07_May13_Radioss_RBEs_MPCs_index.html
0 -
Thank you Rahul , Thank you Prakash /emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
0 -
I have a also question about MPC.
How do I create MPC's in HyperMesh for the RADIOSS Solver?
F.M.
0 -
I would also like to know how to create MPC in Radioss user profile to model cyclic symmetry.
An example using this type of kinematic constraint would be appreciated.
0 -
Hi Ivan,
For cyclic symmetry in RADIOSS we have a workaround.
Select the nodes where you apply the boundary conditions, and put imposed displacement (/IMPDISP, and keep icoor=1)load on those nodes with zero magnitude function in the required directions.
X Y
0 0
1 0
0 -
Thank you for the tip, however I am unable to properly apply this workaround. The reason is this model probably needs node to node constraints like MPC. Could you please look into the files?
0 -
Hi Ivan,
Reviewed your files.
The model is not a cyclical symmetry case but a planar symmetry problem. There are some limitations in RADIOSS if you want to continue with planar symmetry.
If your purpose is only to reduce the run time I would recommend you to change the function defined for /IMPDISP load. That is, instead of ramping the load in 1s you can ramp in 200 or 300ms and run the model for the same time.
