Hi
i want adjust normals for the surface
how to write macro for the same
You can use from the pull-down menue 'Geometry->Check->Surfaces->normals' to reverse surface normals.
Regards
But i need to change the normal of the surface at a shot just like elements
one more eproblem i am facing if perform a geomtry cut operation normals will also change
please help
