I've tried to connect some parts with spot weld elements in HM. The mesh around these spots is very fine, 0.5mm, but the spot weld has a diameter of 2.5mm. After the analysis, the stress peak is always on the element, wich is connected with the spot weld element but normally, since the weld diameter is 5 times larger than the element's edge length, also the adjacent elements should be directly connected to the weld element. Am I right with this idea?
Regards
