Calculation of area
Updated by Altair Forum User
I wanted to apply a load on a surface for which I want to calculate the surface area so that I can apply a pressure load on the surface instead of concentrated load ? Is pressure load applied is evenly distributed on the on surface or it is mesh or node dependent?
1 - 7 of
71
suppose i want to apply a pressure load on the non-uniform surface then how can calculate the area on which load is appiled?
Altair Community Member
Updated by QuyNguyenDai
pressure in particular direction ?
By definition, pressure is applied in perpendicular direction of element/surface.
Please refer attached screenshot from online help.Tool page: Mass calculation option would help you to get area.
