I need help regarding assigning local co-ordinate system.
I placed a local co-ordinate system at one node, which is at certain orientation w.r.t. Global CSYS.
After analysis, I observe positive displacement on the node where local CSYS is applied.
Is it the expected behavior?
I expected the newly defined CSYS (or the origin node) to remain stationary when results are resolved in new CSYS.
Please suggest if I need to do something different.
Refer to attached image of crack tip and local CSYS defined (small dot shown in grey colour, a little downwards of crack)
Ashish
