Hi all guys.
After inspire have run completely, I display that result.
It show dialog No Shape Created. And my design space is not optimize.
There are only appear and disappear.
Please advise.
Check the loads, seems like loads not present or unrealistically small.
Thank you for your answer.
I can escape from No Shape Created issue.
But right now I am facing with 'Design Violations' issue.
It show error about 'Stress Constraints'.
Could you suggest me how to optimize proper number of 'Minimum Safety Factor'?
Under Stress Constraints, the default Minimum Safety Factor is automatically calculated based on the lowest yield stress in the model, but you can enter a different Minimum Safety Factor if desired.
https://en.wikipedia.org/wiki/Factor_of_safety
