Hello,I want to upload the results from Ansys 18.2 to HyperView.Loading files with RST extension.I do not know what to choose in Select Model Reader and Select Result Reader.
Model Reader = nodes, elements, sets,...
Results Reader = Displacement, Stress,...
I am sorry, but i do not understand.
What should I choose for an option in the window: Select Model Reader and Select Results Reader?
In general, HV can detect automatically the reader depending to your results.
If you see this windows, it means that HV can not found the reader automatically.
Your version of Hyperview?
My version is HyperWorks v13.0
Aiiiiie, too old for Ansys 18.2 I think.
Try v2017.2 !
I do not currently have access to a newer version.Is there a way to solve my problém?
No way.
ANSYS 18.2 is latest release of ANSYS for this moment. This release is (maybe) supported by latest release of Hyperworks, but not v13 nor v14.
I have installed version 2017.2.The error is current.Please, give me an advice.
I write a bachelor work and start to cut time.
I think still we cannot import Ansys 18.2 results files to HV 2017.2. PFA screenshot from help for 2017 & i dont see any information in release notes of Hv 2017.1 or 2017.2.
If possible please share input files and results files of Ansys 18.2 version. we will check same at your end on HV 2017.2.
HyperView 2017.2 supports ANSYS structural, thermal and electromagnetic results for ANSYS v18.0 and earlier.
Requesting you to share Ansys18.2 .rst and .cdb files using secure ftp link available in my signature.If file size is too big than please share output for simplified/small model.
I confirm that Hyperview 2017.2 can read without problem the results of ANSYS 18.2 :-)
Again good news: Hyperview 2017.2 can read no problem the results of ANSYS 19.0 !!!
